need some help
Jon581
Dirty South,FL
on my 93 2.3 i was going to move my trailer so i hooked it up plugged it in and with the truck running i turned the lights on.well something happend cause now none on my parking lights work only head lights and the abs light is flashing now.what did i fry or blow?i checked every fuse i could find there all fine.
Fuse #16 is for that circuit. Does the fuse show power with a test light? If it shows power on both sides of the fuse, check for power in the brown wire from the headlight switch with the park lights on.
i tested every fuse under the dash bothsides and they all work.what would it mean if there is no power to the brown wire?and what would have caused it?
