Need some Help
petethehack
Payson AZ
Hi All,
I just bought my first Ranger and I have a question. My check engine light came on and 2 codes came up. 1st was a bad CPS (or bad CPS connection) 2nd was EGR had restricted flow. The truck purrs like an old Tom Cat with only 115,000 miles and I am assuming with a faulty CPS it shouldn't be running at all. The only odd thing about the way it runs is that when I start it (hot or cold) the RPM's jump to 1500 and VERY slowly drop to a nice 700-800 idle. Sometimes it will fluctuate a little as it is slowly dropping. When I pop the hood and have someone rev the throttle I can hear a very noticable and loud sucking noise, just like a carbureted engine when you remove the air cleaner, coming from the back of the engine. Could all this trouble be from a vacuum line leak or a leak from the intake? Any suggestions would be appreciated, cuz I am stumped.
1995 Ranger XLT standard cab 4x4, 4.0 Auto. Bone stock, except for the dents.
Not exactly sure on the newer electronic engines, but sounds like you have a vacuum leak somewhere which could very well cause your check engine light problem. The EGR sounds like it either needs cleaned or replaced, usually its just best to replace them.
Hey I have a 96 4.0 doing the same thing, except the CPS code. The motor has a very worn-out growl to it like its struggling to climb RPMs. But it still has tons of power/life. Im getting the EGR restricted flow code as well, and think it has something to do with it. I recently overheated my engine (a couple times and once very bad) and I noticed it during and after the bad one (the growling noise). All vacuum lines are properly hooked up to my EGR system. I even have the Idle issue. My EGR system however is newer and takes two flow readings being a 96 DPFE I am unaware of the year they implemented this... Planning on changing valve and cleaning MAF... I'll post results... If you find a "cure" please share it as well because it seems we are in the same boat
