Trfsrfr
- May 27, 2013
I just purchased what I hope is the deal of day for me.
See, recently I constructed a flatbed for my 93 3.0L Ranger, and as usual I overbuilt it. It's way to heavy. With it's 3.43 gears and the 235/75/15's I have on it, (195/70/14 stock size) it barely moves.
So today I purchased a used diff, for $50.00.
It needs wheel cylinders and new shoes, but I am not quite sure what I have;
The kid I bought it from advertised it as an 8.8...
So here are the specs;
10 cover bolts,
Tag (which I am assuming is correct because I counted the rotations) reads 313B 4L10A759E11. So 4:10 gears, which is why I purchased it.
It is 56-1/2" WMS to WMS,
Its drums measure approx 10-1/2" O.D., and the shoes are 2-1/2" wide,
The outer-to-outer edge of the shock mounts is 29"
The center-to-center of spring perch mounts is approx 39"
The spring perch's are located on top of the axle tube,
It has an ABS sensor,
The tube diameter is 2.95 at the diff housing, but then tapers to approx 2.80 at the spring perch.
I give this info because I need to know;
A - Will it bolt directly in?, and;
B - what shoes and wheel cylinders do I buy for it?
Any thoughts are much appreciated.
Thanks!
10 cover bolts,
Thanks!
