Need some direction
'99 EB Explorer
Sudbury, Ontario, Canada
hey guys. I just picked up a '96 explorer with a 302. Was just wondering if anyone has a list of what's needed out of the donor truck to swap it in to my '99 explorer. Haven't worked my way over to the tech section yet. Any help here would be great.
Thanks in advance
Edit
Keep in mind that I'll be swapping in my D44 and 9" too
Also would like to know the best option for replacing the all wheel drive that's currently in the donor truck
Replacing awd is as easy as swapping tcases. You will need ecu, engine harness, throttle cable, cruise control servo and cable, power steering pressure hose, radiator, tranny lines, motor mounts, exhaust, altenator harness, and the Evtm for both years(electrical is different for those years, but not too bad)...
SVT
Sweet. Thanks for that. Erm, when I said best option for AWD, i meant something more along the lines of 'which t-case is compatible to swap in?' :P
