Mike828
What's up guys, yes I'm a noob and no expert, but need some friendly advice and thanks in advance..
I have a 2000 4.0 OHV 4x4 auto with 106,xxx and it started misfiring in #3 cylinder. Pulled the plug which had 6,000 mile aprox. and it's fouled. Put in a old from the last swap and it ran fine for a day and now I feel it missing again so I put in a non fouler and a new plug, not much better.
Going to check the compression on #3 this afternoon and will update.
What would you do?
It has a 5R55E trans.
Is a 4.0 sohc an easy swap? What would I need?
Time is somewhat critical in that I need this truck running asap, it's a work truck that tows 2000lbs daily and reliability is somewhat important too.
It would be great if I could use the truck until November and then do any major work but I don't see it happening.
And I'm by no means a rich man but can throw a couple dollars at it.
Any advice?
What would you do?
Any advice?
