- Feb 28, 2001
- Dayton Oregon
- 2.3 (4 Cylinder)
- Manual
- Total Lift
- 6
- Tire Size
- 35"
This is the engine from my Geo Tracker, it's a 1.6L aluminum block with sleeved cylinders, before I pulled it it did not leak coolant into the oil or anything else like that. The reason I pulled the engine is excessive oil use from worn pistons and/or rings, it has 297k miles on it but the bores are straight...
My question is, should I put the $300 in parts into this engine or find another to rebuild for the thing? There's another on Craigslist for $200 for a long block or $300 for another that has injectors and such (but isn't the right intake or exhaust manifold)... I'll be rebuilding no matter which way I go, kinda hoping the engine I have is fine but being in the #2 main bearing kinda makes me leery... I know the best solution is to not run a broken engine, but funds are tight, although if I'm building it I kinda want it to last
So, rebuild my current engine or get a different one?
