need help
fredsranger
edinburg texas
will coil springs from a 99 ford ranger 4x4 lift my 95 splash 2wd ,and will they fit and if they do how much of a lift will they give me
Don't know from experience but I would assume that they do except that your ride might be kinda rough and you will probably need better/longer shocks. I'd guess you would get 2" or so if you have a 4 cylinder
ur 95 has longer coils because if the i beam front end. the coils off the 99 4x4 A arm truck wud prolly actually lower ur truck( it they fit that is) and also the 99 might be a torsion bar not coil
