BroncoLover12
Hello all,
I am new here and need help. Any information is appreciated!
So, I got a hole in my fuel line (from fuel pump to fuel filter). To replace it I took a risk and cut a hole through the floor in my trunk to get an easy access hole to my fuel pump. It was going to be a simple fix, but in the process of cutting this hole I cut straight through a DIFFERENT gas line. Pictured, at the top you can see where I cut through the wire. I followed the wire, and it seems to go straight passed the fuel filter and to the engine.
I was wondering if anyone knew what this line is for? Where can I find what it connects to? It is hard to follow too far beyond the fuel filter, but I should be able to find it if no one is able to respond on here, just figured I'd ask to make it easier. Lastly, is there a certain store or website that I should purchase the new lines from?
I am considering changing the fuel filter and maybe fuel pump while I am at it, so if there is anything else that is relatively simple that I could try to do please let me know!
