Johnnyboiranger22
- Nov 1, 2017
- Age
- 29
- St Petersburg, FL
- 2.3 (4 Cylinder)
- Automatic
- Tire Size
- 215/75/14
Hey guys. Have finally been running my 91 Ranger and taking it on little test drives (finally finished repairs and engine swap). Now having time to focus on the little thing i noticed my fuel gauge is not working, I dont believe it the fuel pump with sending unit because i went through 3 of those and gauge never works all fuses look fine. Could this be a cluster issue or some other issue? I also ran the OBD1 reader coming up with just a couple codes, one a brake switch which i know switch has failed. My main one is code 21 ECT sensor out of range. If I understand correctly the ECT is the sensor plugged under and into the intake manifold with two wires instead of the coolant temp sensor for gauge which is just one?
