Need help with lift
Shawn_248
Lexington SC
My 93 single cab 2.3 has a bone stock suspension. I want to do the washer lift on the front just enough to bring it level since funds are low. I read in the tech library that the stock bolt in the I-beam only allows for 3/4" of washers. I wana replace that bolt but don't know wat size it is. I know to only use grade 8, but would be thankful if some1 could tell me wat size bolt and length to replace those bolts with. Any help or advice would be appreciated
go to the tech page and the bolts are 3/4 10 and you need like 2" and a 2" coupler about 12 washers i just did it for 60 bucks wit alighnment but i did it all myself
