Hey all,
I dropped a 5.0L out of an '89 GT about 3 years ago in my Ranger. I put a cobra top end on it from a '94 Cobra (Gt40 heads, Cobra U/L intake, Cobra TB etc). Running 19# injectors and 19# factory MAF. I'm wondering if it wouldn't highly benefit from a bigger fuel pump.
What is the flow of the factory fuel pump in a '93 4.0L Ranger? From what I can find its comparable to the factory Mustang fuel pump which is a 88lph pump. The factory Cobra pump was 110lph!
Most mustang guys ditch the factory pump as soon as they start adding mods. Good rule of thumb is 1/2 HP per LPH. By that rule the factory Ranger pump shouldn't be used beyond 176HP! With the mods I have it should be putting a solid 250HP to the wheels, thats roughly 300HP at the crank. In theory this pump is over driven by a LOT.
This leads me to believe the factory pump is way under powered for my setup. I'm thinking about jumping up to a 155LPH pump or possibly even 190LPH pump. Most mustang guys go with 190lph pump once they start doing H/C/I swaps. But they are rated for nearly 500HP, I think 155lph which is rated for about 425HP would be more ideal for me.
I believe this might fix my long battled troubles of terrible throttle response and just overall performance loss (Terrible acceleration and detonation on the top end with mild timing advance). We don't have to get into the endless amounts of things I've already done to try and fix the performance issues, this post is specifically to discuss fuel pump ideas.
Thoughts?
Thanks!
Thoughts?
Thanks!
