Need help with dana 44
DANIELVINCENT
Solid Axle Swap
TRS Banner 2012-2015
Vancouver WA
so i picked up a high pinion 1978 ford dana 44 and going to narrow it to the EB axel but i need new ring and pinion.... there is a 8 lug on CL that has 4.10 and its a HP also. can i use the ring and pinion from the 8 lug to put in my 5 lug?????!!!! need help fast because it might go away
thanks dan
Yes, as long as both axles are high pinion, you're good to go!
