need help with coils asap
crazywhiteboy
May 2011 OTOTM Winner
OTOTM Winner
Solid Axle Swap
clearlake, ca
have fullwidth d44 and 9inch..in the middle of building extended radius arms with ballistic joints and have yet to get coils. what brand coil should i get for good flex, im running 37's and have cut fenders..already have 63inch chevys, going to run them under the frame...soo what coil should i get? thanks:dunno:
you might try early bronco 5.5 progressive coils from james duff i have there 3.5 in springs and run 35's with a little trimming
im lookin for a coil thatll give me good flex and articulation..from what ive heard, duff coils are pretty stiff. what do you guys think about wild horses progressive 'crawler' coil or the bc bronco coils? i think those are some where around the low 200's or so. any opinions on those springs? what about the skyjacker softrides? im looking for a taller coil, like 6.5" to 7" to help me clear the tires, and thatll have alot of travel....thanks guys.
I just replaced my coils with Deaver superflex 5.5 inch EB. They are about the same height as the 6 inch RBV coils I was running, but much more flexy
Im running a 7" Skyjacker softride coil for an Early bronco, but it has the same P/N as the 6" softride coils for the Fullsize Bronco/F150. They sit around 20" when loaded, supercab with winch and bumper. I'm running prerunner fenders which give me about the same wheel opening as trimming behind the stock flare would, and am running fairly wide 37's with minor rubbing while flexed/turned.
You could get away with less trimming/lift if you push the axle ahead 2-3" or if you choose a skinnier tire.
I think you could get away with a 5.5" coil and trimmed fenders on 37's pretty easily. I've got very minor trimming with the 3.5" coils and 35's.
Wild horses coils are 204/375 rate for the 3.5" coils. The 5.5" are a tad stiffer, I want to say like 220/275 but can't remember exactly.
I've got the 3.5" version and am very pleased with how they perform. Its got decent road manners (DD) and it does things like this on the trail:
I have a set of Cage 5.5 progressive rate springs I've been trying to get rid of....
$150 puts em on your doorstep.:icon_thumby:
-Said coils w/ 36" tires. Would easily clear 37"s w/ cut fenders
sooo...was doing some research, and found out that devear makes springs for both bc bronco and wh...if if thats the case, why are they more expensive on deavers site, and bc offers a 6.5 and 7inch coil.
Dunno bout the prices and such, but The Deaver 6.5 springs are what I replaced my Cage 5.5" springs with. And they sit lower:annoyed:
Whats wrong with siting lower? I thought droop was all the rage these days, and up travel was so last year?
uptravel is better than down.:thefinger:
so. i think im going to go with the 6.5 bc bronco coils. and for spacing them off the frame, i think im just going to fab my own buckets in the same design as the bronco graveyard buckets, but using 2x4 or 2x6 and some 1/4" plate. anyone know what the overall diameter of the coil is?
and just got my 31spline spool and 1310 yoke yesterday too!!!:yahoo: have a few other things i want to get before i start cutting into it tho
