- Jun 30, 2008
- Automatic
Wahoooo! Thanks English Dan - that did the trick.
I took it off the truck, snipped the brown wire and benched the motor. Took it all apart, motor and gearbox to be sure I didn't miss anything. Found the nasty orange plastic bits in there. Made a new sleeve from rubber fuel line that matched the dimensions. See pics.
While I was there I tested the motor, cleaned all contacts, greased up bearing and gear surfaces, re-gasketed it with RTV and re-assembeled.
I was delighted when it worked again first try (wasn't expecting that after all it's taken to get to this point). Guess I didn't need the replacement control modules or switches after all
Thank you all for the great help - I'm good to go
Made an equivalent part from rubber tube:
