Broncodude
Hay all, recently my 84 BII had been taking turns not turning over, in other words sometimes it would but now it won't at all. I have cleaned every connection from the battery, solonoid, relay thing on firewall, and starter. I get 12 volts on both terminal sides of the solonoid when the key is pushed to start. I thought It was the starter since it was an original so I took it to get it tested and it worked fine. I decided to get a new starter just to be safe cause the rest of the engine is only a year old so I installed the new starter and nothing, not even a bump. I'm getting a complete ground or good connection thru the starter cable. Got any ideas on what to replace or try next ??
