SittinInTheCheapSeats
- Oct 15, 2013
I have a 1992 Ranger 2.3L with the Mazda M5 transmission. The truck has 259,000 miles with no engine or transmission work in the past.
I started noticing fluid under the transmission and concluded that the clutch slave cylinder was leaking. After going through a quart of brake fluid, the shifter became VERY sloppy. I had to keep rotating the shifter knob counterclockeise in order to shift properly and it became difficult (but not impossible) to find the gears. I decided that it was time to drop the tranny and replace the slave cylinder and fix the shifter problem.
When I drained the tranny fluid, the typical gunk came out as well as 2 metallic pieces attached to the magnetic drain plug. I attached a pic of the part. I suspect that it was originally a ring of some kind. If I lay the pieces back together, they appear to be approximately 7/8" inside diameter. I went ahead and dropped the tranny out of the truck to replace the slave cylinder.
I was hoping to NOT do an overhaul on the transmission since it is in excellent condition with no whining.
Can someone help me identify the part? Am I looking at an overhaul?
