fletcher969
Hi all,
1996, 2.3L, Auto (A4LD?), 2wd, 190,000mi.
No idea when, or IF my tranny filter has ever been changed, or if the tranny has ever been serviced.
Forgive my lack of brevity...
For the last few weeks, my transmission has been acting up a bit. At first it was some rough shifting into 2nd and 3rd, but I changed the fluid, and it ran better for several days, then it slowly began to act up again. A week or so later I could hear a discernible "whining" sound (reminds me of a turbo charger) when shifting into 2nd, and more so into 3rd, with the shifting into 3rd being more on the rough/jerky side. For the last week or so, the whining noise remained, but the shifting into second improved (mostly normal), and is operating fine, but 3rd has regressed into what I believe is a slip (revs increase, acceleration seems to flatten, then 3rd engages a little roughly if acceleration is continuous, but smoothly if I let off the gas when the "slip" occurs). All other gears have operated exactly as one would expect...no problems.
Today everything changed. Lots of stop-n-go traffic...noticed 3rd really struggling. Got off the expressway, and no sooner than I did, the transmission started kicking out of 3rd, and wouldn't stay. Initially it tried to shift, but it would immediately kick back into 2nd. A few minutes later it started to "fluctuate" (as if continually trying to shift into 3rd, but remained in second. Eventually it got to where it wouldn't move if I had it in Drive, but it would stay in 2nd gear if I had it in the 2nd or 1st gear positions (O/D light was flashing...limp mode?). I limped it home, but it remained in 2nd gear the whole time, and it would "disengage" if I put it into the Drive position while moving. Let it sit for 45 minutes...then took it down the road to scan my codes whereupon it drove normally for about 5 minutes, then started a quick regression into "limp mode" again. Scanned then cleared my trouble codes, and surprisingly, after only sitting for 10 minutes, the tranny operated normally for about 15 minutes, then went back into limp mode again (though I don't recall the O/D Off light flashing again after it did initially).
I'm hoping this is something simple like a clogged filter, vacuum problem, or something it's not liking from the PCM or TCM, versus a trashed tranny. The fact that it runs normally after it's sat awhile, and after the codes were cleared seems to indicate the tranny is "physically" alright, but has either a heat-related or electrical problem, or something else that affects it after it has run awhile.
I'd certainly welcome anybody input or related experiences that might point me in the right direction on a limited budget.
Here are the codes I pulled today in the order listed as they have accumulated over the last month approximately:
P0125 - only "current" code. Insufficient coolant temp for closed loop fuel control (I can confirm the thermostat is inoperable, but how is this related to the fuel control, and would this explain my off-idle hesitation?...another topic perhaps).
P0761 - shift solenoid C performance stuck off (seems VERY related to my shifting problems...no? Hoping too that C=3rd...would correlate with the issues I'm having with 3rd)
P0420 - catalytic system efficiency below the threshold, bank 1 (this is an old code I keep getting...not sure if it's O2 sensor related or what.
P1000 - Continuous OBD systems readiness test not complete
P1701 - reverse engagement error (reverse has on occasion "kicked" into gear since the tranny started acting up, but it almost didn't go into reverse on two occasions after my troubles started today).
Does anybody have any ideas? I'm stuck "limping" around until this is resolved, and it's going to cramp my style very quickly if work migrates too far from home.
Please....anybody?
Thanks.
Dave
Please....anybody?
Thanks.
Dave
