KYEdge
Well, I'm pretty certain it is a bearing going out; it sounds dead up like the rattling screech that a bearing makes when it starts to fail. The problem is I can't figure out what bearing.
It will not do it with the truck in park or neutral and just revving the engine. If I do that the engine sounds perfectly fine.
It will only do it while moving, and seems to manifest itself the most when accelerating above 40mph. RPMs don't seem to be a factor in it starting (just the speed, mainly increasing speed) but the RPMs DO seem to change how fast it sounds like its spinning.
The noise fades away a few seconds after I reach a steady speed, but will come back anytime I blip the throttle or speed up a few miles per hour; then once everything is steady again it fades away. This of course is confusing the crap out of me. I can go rev it in the driveway to 2500 RPMs and it sounds healthy; but I pull out onto the road and start accelerating away at 2500 RPMs it starts to squeal right around 40mph. Once I hit a steady speed say around 55 or 60 and it goes away I can blip the throttle and it comes back, but if I don't keep the throttle down to actually accelerate the noise just fades away again.
I can't even really pin point the general location of where it comes from since I'm in a moving truck. I think it seems to be coming from somewhere near the front of the engine bay on the passenger side (ie maybe around the alternator area).
I have no idea if it is the speed that causes it and the RPMs just go up as the speed goes up so that is just a coincidence; or if it is the RPMs that cause it and the speed just goes up when the RPMs go up.
