Need help finding a part.
pollux55
Hey everyone. I just got my truck less than a month ago so I'm new here. I used to have a Dodge Stratus and found a great forum with very helpful people. I'm hoping to find the same here.
The other day it was well below zero here in Northern Wisconin and I put some stuff in the passenger side of my Ranger and shut the door. I got in and the dash said door ajar. I opened and closed my door, still ajar. I grabbed the passenger door pull from the inside and pulled. It didn't move so I pushed it out and it moved a little. Pulled on it, but it wasn't enough to close. Pushed one more time and pulled hard this time. Well being so cold I tore the door pull right off.
The door pull is in one piece, but it has some of the trim that it's attached to still attched to it. I need to find that larger black piece the door pull is screwed to. I'm hoping I don't need the entire door panel...it doesn't look like I do.
I have crank windows and manual locks if you need that info. Can someone help me find that part or at least the part number?
I appreciate the help.
Thanks,
Joe
That's probably gonna be one of those items you have to go to the dealer for (check it out, occasionally certain dealer parts are not that expensive). Its a separate piece on the panel, I can't see why you'd need the whole panel.
Another option is a junkyard (anything from '98 up to at least your year should be the same, very common part that can be easily found there).
Hope that helps
Welcome to the forum :beer:
