Tiph83
- Apr 1, 2013
A quick run down. I have a 94 ranger 4.0 5sp. I done a but of custom work and one thing I had to do was put a 90bronco 2 tank in my truck with a 88 bronco 2 fuel pump assembly. The wires to the pump from my truck are pink/black, yellow/white, black, yellow and white. The harnes for the bronco 2 fuel pump has pink/black, orange, black, yellow/white. I had it wired up with all colors that match and the black/yellow going to the orange. It's an fine for two months and it just died going down the road which is where I have been sitting working on it for four hrs. I checked the old fuel pump it wasn't running. I got a new one and installed it primes but doesn't run when turning the key I hot wires the pump and it try's to start but doesn't. Any ideas will help if you need more info ill give what I can. Please help
