jmabarone
- Sep 2, 2008
Okay, so my calamities continue. After changing the headgasket on the 2.3, I discovered that it was again letting water into #1, so I decided to get a new engine. I picked up a 2.5 from a 2000 with 120k miles.
The 2.5 was a long block swap except for the lower intake manifold, and the cam and crank position sensors. Everything else came from the 2.3 (which was running just fine except the bad head).
The truck will start, and idle very poorly. I can rev the engine up, and it will run fine. As soon as I let off the gas, however, it will stall out. I can try to save it by giving it gas again, but it works only sometimes. When I go to restart, it will turn over without any hint of catching until I start blipping the throttle.
I've change the fuel filter, checked fuel pressure (and it is good), and tried the ICV and TPS from the 2.5...all have had no effect. As I said before, the truck ran fine prior to the swap, it was just eventually going to hydrolock. So, I'm thinking there is that could have suddenly gone bad.
Does anyone have any ideas? I've searched endlessly, and I can't find any culprit. I don't want to take it to a shop mostly because I think they will just throw parts at the truck until it runs.
Thanks,
Jake
Thanks,
Jake
