Bump, i finally started and ran into a couple of problems, first off , i thaught there was a plug in the firewall for the clutch master cylinder? is it the same one that my trans shift line runs through? if so im geussing i need to drill the 2 holes for it to bolt up, also what year end peice(attached to drive shaft and slides over the spline in the trans/drive shaft can i use, the truck is a 98 shortbox single cab, and the donoir truck is a 94 long box. i think thats all the problems so far, i would apreciate any help, im trying to get this summed up by tomorow night as mondays are my days off.
