MA Ranger
- May 19, 2009
- Automatic
While replacing the thermostat on my '94 Ranger (2wd, 3.0 L V6) today, I accidentally dropped a 1/4" nut (it's about 1/4 in thickness, 3/8" in diameter) down into the space where the thermostat is mounted in the engine. It initially wound up behind the "column" that the bolt on the left side of the thermostat housing goes through ( I could feel it with one of my fingers, but couldn't get a good grip on it to pull it out). When I tried to get it with a bent coat hanger, I some how managed to push it deeper into the cooling system and couldn't feel it anymore.
I haven't attempted to start the truck since this happened - I don't want to damage the water pump or cause a clog in one of the "water passages" in the block and risk seriously damaging the engine. A mechanic I know told me the only way to prevent serious damage at this point is to remove the intake manifold (removing all the requisite parts first - fuel rails, distributor, etc.) and hopefully I will find it, but I may have to pull the cylinder heads off too. He agreed that I could cause serious damage to the engine if I didn't find and remove the nut.
Don't know if this, or something similar, has happened to anybody else - I would appreciate any advice/help I can get. I'm going to work on taking the intake manifold off on Monday. I have a Haynes manual and a local mechanic that can answer questions, but I'll be doing 99% of the work. I plan on taking pictures of everything and labeling everything as I take it apart. Thanks again for all the help in the past - hopefully this will turn out good too.
