need help: 85 2.0l wiring and vac pics
pappy6
this problem solved
If I can remember I'll get you a pic of the vac diagram. Can you describe which vac lines you are having trouble with? I feel like I know the vac lines like the back of my hand.
Hey thanks!!! actually i think the ones towards the left rear of the engine give me the most problems. I did remove the air supply pump so the one(s) from it blocked. I put new oil seals on the eng and painted it as well as everything under the hood over the last 2-3 months and can't remember where thins go....have a haynes manual but does not help....also waht are the two parts that the vac lines originated on the intake manifold called? grrrreatly appr any info....pappy
sorry i am repetitive but I am an ol f++rt !!!!
