Need Fast Tire Help!
rededge02
So i took my ranger into fourwheel parts today to put my 3 inch body lift on. they were also going to install my 33/12.5/15 tires. but the guy said that they wouldn't fit even with a torsion crank. he said to run 31/10.5/15 and if i wanted to i could run 32/11.5/15 but i would have some rubbing??!! Now I have a 02 ranger edge 4x4, doesn't it come stock with 31's so with the 3in lift why couldnt i upgrade without rubbing? Im just confused. And if i do choose to run the 33's regardless do you think a 1inch torsion crank would make them work? Also if you run the 33/12,5 with a 3in body do you have any problems with rubbing offroad?
I stand to be corrected, but I'm pretty damn sure those 33's will fit with that 3 inch body lift.
If you do crank the t-bars, don't forget to get a front end alignment.
I'm running 31/10.50's on a stock 99 with no crank. No rubbing either.
John
i am running 33x12.50 on 15x10's with a torsion crank and they only rubbed a little on the lower valance. on my 03 fx4 levl II i would have been better of with a 15x8 rim but you will be fine with BL
I'm runnin 32's with just a t-bar crank with no rubbin... could have fit 33's.
I'm gonna do a 3" B L after the first, Then i'm gonna be runnin 35's with just the body lift and t-bar crank.
My 95 4x4 has a 3" body lift and I'm running 33x12.50, They only rub slightly when I'm really pushing it off road.
