KWAD RCR
So here's my problem. I have a 1998 Ranger XLT, 4.0, 2wd, automatic. I bought it with a check engine light. The codes were p0401, p0172,p0175, and p0735. The p0735 and p0401 was taken care of. I couldn't figure out the other two codes so I took it to a very reputable machanic. After two weeks, MAF sensor, another CPU, O2 sensors it still throws a check engine light, rich bank code. The fuel pressure was bleeding off so I brought it home and pulled the upper intake off so I could pull the fuel rail off and see if any of the injectors were leaking. None were leaking that I could see. This is where I need help. Anyone else have this problem?
