ericlerouge
my truck has the fm-146. i had problems downshifting when i bought the truck. i swapped in a 2.3 td engine and put in a new clutch, slave and pressure line. I did'nt change the master.
Now i have the same issue. i have to double clutch every downshifts in every gear. But it shifts fine upward.
I wonder if my clutch is bled right/if the master is letting air in? or, if all the synchros are toasted, all gears?
is downshifting needs more clutch movement then up shifting?
