Need Clutch Recomendations....
benson79
I need to replace my clutch. my truck is an 03 FX4 Level 2, 4.10 gears.
I mostly use as a DD, but occasionally I go off road. I will replace the flywheel as well.
I don't want a stock clutch, would like something a little more grabby yet still suitable for a DD.
So far I have looked into Hays http://www.summitracing.com/parts/HAY-90-344/
Zoom http://www.summitracing.com/parts/ZZZ-HP2117-1/
and a SPEC stage 1 clutch (SF671)
any suggestions would be appreciated
the difference is just the materials used on the friction disc
those original sound, luk RepSet lasts 7 years in general but others its not better it lasts 3 to 4 years
Ceramic clutches are the best clutches you can get. Kevlar and Organic clutches don't stand up to heat as well. They wear away a lot quicker with heavy use.
I have used Centerforce clutches in my trucks. They are a good up grade from stock and work well on the street and off road.
