need clutch master, slave help please!
pillen140
winston-salem, NC
ok the truck..... '95 ranger 4x4, 3.0, 5spd.
never had any clutch problems. today, my truck drove fine, went to leave work, all the sudden, my clutch pedal does nothing! put it on a lift, check to see if any leaks from slave or master cyl.... and non! no leaks! no fluid in bell housing, nothing!. bleed the system anyway, still very little clutch pedal, not enough to be able to drive it....
so, im guessing its most likely the master cylinder? i know the slaves are very common, but dont they usually blow out when they go bad? im really frustrated, cause i just spent almost $1000 on this truck fixing it after i rolled it. oh, and after bleeding it, the clutch fluid level doesnt go down, or show signs of leaking! :icon_confused: any help would be great, cause i live real far away from work, and have no ride home. thanks in advance!
