need advice
Lexington, SC
i have a 1999 ranger 4x4, auto,4.0l changed out the plugs,wires,fuel filter
wednesday and it ran great and then parked it.Went out just then to start it up all it will do is turn over,battery is strong but just wont fire up.checked fuses in cab and under hood all ok.also replaced coil when i did the plugs.drove around after i did work and was fine now it won't start,any
suggestions would be appreciated.
thanks,
Brian
did u check for spark or fuel pressure. some times changing a fuel filter that was clogged badly and replacin it with a newone will let the new one suck in the stuff that the old one didn't had room to suck inside and clog ur new one, i always flush out a tank with the lines diconected and draining into a bucket so the sediments will come out before hooking them up to a new fuel filter
