need a picture from a 94
p575
i need a picture of the fuse panel from a 94 (with a 4.0 if it matters) some jackass pulled all the fuses out of the project i bought, and i can't find a reference to replace em by. thanks for any help.
If a 94 2.3 w/5 speed is the same I can get it for you.
doesn't have an owners manual, and as for the 2.3, i'll take it. don't see any reason why it would be any different.
thanks
Here ya go dude.
Let me know if there's anything else you need for reference.
This help?
('94 4.0L std cab XLT 4x4)
Oops, got beat while trying to charge up my cam batteries lol
Hahahaa... Got beat by an hour too!
There's one fuse that's different... what is that one used for? Fuse #5
(I don't have the manual, only the cover.)
Hmmm... I see a 15 on yours where there's a 20 on mine, which (according to my manual) is fuse #13 (maybe the cover marks them different?). It says Turn lamps, B/U lamps (Backup, I assume), Turn indicator, Daytime running lamps. It also says it's supposed to be a 15A, which leaves me wondering why mine has a 20 in there (I'm the original owner of this truck, and I cannot recall ever changing that one) :icon_confused:
#5 as indicated by my manual is for the "Premium Radio Amplifier (20A). There is no fuse at all in that socket on mine or yours (the one under where the blue wire goes across on mine).
whats these wies probed into the fuses?(both panels)
The wire on mine powers a lumbar support bag that I put in from a 1989 Sable. I was too cheap to hardwire it into the actual truck's wiring harness.
I also would have done that by now, but since I never really look at the fuse panel to remember, it hasn't got done.
thanks a lot, thats exactly what i needed.
Mine is power for the ARB locker wiring (switched with ignition key)
