4.56-FX4
- Apr 5, 2008
- Age
- 49
Axle upgrade and lifting questions
Ok, guys, I just got done reading this http://www.therangerstation.com/forums/showthread.php?t=14540 thread.
Don't worry I DO NOT plan on putting 44's on my truck.
Rig info: Right now, I'm running a completely stock (drivetrain-wise) 2003 FX4, so I've got the 4.0L SOHC engine with the 5spd manual tranny.
I've got it sittin' up on a 3" BL and runnin' 33x12.5 Boggers with custom front/rear bumpers and sliders, 4.56 gears (hence the name), and an Aussie locker in front.
I've thought about going with D44 axles from/for a Jeep TJ (links below),
http://www.4wheelparts.com/PDT260543.aspx
http://www.4wheelparts.com/PDT260538.aspx
I've thought about getting some 1 ton axles from a fullsize,
I've, honestly, thought about a little bit of everything.
I guess what I'm saying is I'm wondering if you can guide me a bit. I'm running the 4.0L V6 and 5 speed tranny.
What axles would be "perfect" for this rig (yes, I realize that's very subjective, but I'd like to hear your suggestions)? Would D44's front/rear suffice to run 36-37" tires? I'm lookin' right away to run probably 36" IROKs, but might want to move up to 37" or maybe even 38.5" Boggers at some point.
I've heard alot of guys runnin' 9" rear w/ D44 front, too. Thought about that, but not sure.
What about D60 front/rear? Would that be overkill runnin' the engine that I have now? I'm sure some of you've see alot more applications that I have, can you give me some guidance?
Gearing, I think should be in the neighborhood of 5.13:1 for 36-37", but since I'm thinking of going to 38.5, then if you think I should go lower than that, then let me know. I might be alright with 5.29 for a while anyway. I live on Guam and don't drive long distances anyway.
Thanks in advance.
Thanks in advance.
