Narrowed SD60
Lafayette, La
Ok I'm in the process of narrowing a Superduty Dana 60, and if I can ever get a chance while I'm home(I work 21 and 7!!!!) to go get my 10.50 I'll be narrowing that as well. As you can imagine I have a ton of crap to do while I'm in so I only get a day or two in my shop. I try to take pictures and then I post progress at work.
Ok this is what they will be going into eventually. Its not gonna be a hardcore rock crawler or anything, just a daily driver/mall crawler that I can go mud riding and run light trails(only type of trails in south la). I already know I'm gonna get flamed for a few things I plan on putting on it but oh well.
Here's the axle sitting on jack stands ready to be violated.
I stripped it down to a bare housing and removed the axle shafts, be prepared to do some prying to pull the shafts through the knuckle with the seals on. Then I got to work with the 7" grinder, grinding the weld around the "c" until I could see the crack where the metal was separated and after a relentless beating with a BAMFH it never budged, so I cut the tube with a cut off wheel and persuaded the piece out with the hydraulic press. Finally!!!
Before stripping it I determined what width I wanted and settled on a 6" chop giving me roughly 1.5"-2" of tire sticking out. Set up the chop saw and away she went!!!
Now came the fun part!! Lining up the "c" can be tedious, especially on jack stands! I know, I know!!! I ran out of square tubing to finish my axle stand and metal yard is a hour away, and beings I'm too nervous/impatient/hard headed I said screw it and decided to keep going. Anyways, I've got it squared up and tacked it in.
When I come back in I'm gonna burn it in. Still have a few Ni 99 rods, preheat it to around 500, weld it, and then bury the end in sand so it can cool slowly. I know its not much to look at, let's just call it a conversation starter!
Haha, Dana 60 swap and your only gonna mall crawl it? Love it! Sounds like something I would do :icon_thumby:
Keep fabbin'!
BTW is that a high pinion dana 60?
Haha! Well it will see some mud and a few trails, but being my daily driver I have to pimp it out! Its getting 14" travel air bags all around for 6"-8" of lift with dump valves so I can get my broke up back in it, lunch box locker rear and tru trac front, for the street 08-10 Superduty 20" 8 spoke wheels with 35's, and 35" bias buckshot Q's on steels for play time. And if I feel the need to go tear up something I have this being put together also. 88, 351w ho, c6, dana 20, bj hp60, 70hd.
Oh and yes its a high pinion 60 from a 00 F350.
Got any pictures of the axle shafts? It could very well be a D50.
looks like a pain in the ass, sounds expensive, would have left em full width
It's definitely a D50. I can see the little narrow carrier and the big space it leaves inside the housing in the 2nd pic.
Further confirmation would be a pinion nut that takes a 1-1/8 inch socket (a D60 would be 1-5/16 inch)
I s'pose with it being a "mall crawler" though, it shouldn't matter that much.
Ok it turns out it is a 50, I didn't realize they were put into the F350s also. The necked down shafts had me scratching my head wondering wtf. Oh well only spent $150 on it and I'm not real concerned about any strength issues.
I really didn't want to go full width on this truck, its a DD one week a month and I didn't wanna have to run some big ass flares to cover the tires, plus I think it looks a lot cleaner with the axles narrowed and I also have to do an annual inspection. Besides it only took 2 hours and it gives me something to do in the shop while I'm at a stand still on my 88.
I'm sure a lot of people think I'm crazy for going through so much crap doing this to a truck that isn't going to see a ton of off roading, but why not do it? I guess I just like to be different, plus its nice to know if I have a few glasses of crown and get the urge to bail off into a crawfish pond or rice field I have the right equipment to do so! And I know I sure can't wait to get the air bags on it, this thing rides like hell!!
The D50 could be found under pretty much any f250/f350 from 99-04.
