beaterranger
- Jan 6, 2012
I'm seriously beginning to think my truck is the one falling asleep while driving. Here's the scoop:
91 Ranger Supercab, 3.0L, 2wd, 5spd, 287k
The new: coolant temp switch, coolant temp sender, manifold air temp, charge air temp, IAC, fuel filter, air filter, plugs, coil, h2o pump.
The scene: Driving out of town, slight drizzle, overcast, 9pm, 4lane highway, 35 degrees ambient, very light traffic, cruise set at 70mph, full tank.
The summary: This truck has battled a cold for a while now. Starts up fine but WILL NOT permit driving until it is to full operating temp. Otherwise, as soon as load is applied, it stutters, stalls, and generally pitches a fit like a 3yr old. Allowed the truck to warm up and departed on my journey. Achieved target speed of 70mph, set cruise, and all was well. 15min later, the cruise control shuts off at which point I resume control of the foot feed and work my way back to said target speed. Set cruise again, and the universe is once again in balance. 10 min later, cruise kicks out again. At this point, however, there is zero throttle response. All gauges are normal and no CEL. I immediately depress the clutch to verify that the engine has not stalled and to my shock, the engine is still idling smoothly. Off the clutch and still no response for a few seconds but as I begin to pump the foot feed, the engine slowly begins to respond. I hold the foot feed roughly at what it would normally be at cruising speed and almost as if a valve of some sort slowly swung open, the engine came back to life as if nothing had happened. Again I set the cruise and began timing the occurrences. 9min, 30sec recovery, 7min, 60sec recovery, 4.5min, 60 sec recovery and so on until no recovery at all. Again, all gauges remained normal, spit on the heads to verify that they weren't in fact overheating, monitored the headlights for dimming due to low voltage, etc. Nothing. At all. Everything was functionally normal including the idle. No misses, no misses on prior accelerations, no pinging, no backfiring.
My speculation: Cats clogging and not constricting flow until they have reached a maximum temp (btw, no they were not glowing), MAF flipping out, TPS giving me the
, or ECM punching out.
Any thoughts/suggestions? Years of turning wrenches and this has me completely at a loss...
