My wheels arrived.
Explosive
Michigan
Well, this is my Christmas gift from my parents, they arrived today, I'm happy.
And got my drive side rear fender cut and sealed both fenders from inside.
nice! A set of those have been on my to-do list for some time...though there somewhere on the list below "lift" and "tires to go on the wheels".
Yea, my next things are lift and tires and she's good to go.
Now that I'm trimming the fenders, wonder if I should go with 33's still or bigger ?
I'm going with a 6 inch lift.
I'd just browse the "Post pics of your lifted bronco II" thread from beginning to end. I think there are representations of just about every possible tire/lift combo in there.
Yea, I know 33's will clear the 6" lift, but with trimmed fenders I'm wondering if I could go bigger, but if I do, I gotta be sure those won't rub when it flexes.
I bet you could clear 34's, 35's might be pushing it. It'll probably come down to whether the tires have big lugs and the exact offset of the wheels.
Are you regearing? If not stick with 33's but if it were up to me it would have 35's. I ran my truck for about a year with just a 3 inch body lift and 35's and trimed fenders!
lol, that truck looks familiar lepp, I didn't get a chance to check out that trans yet as nobody was around to help me finish getting the vehicle into the garage
How well did the 35's fit like that ? Rub when the goin got rough ?
If you are gonna be doing a lot of hard wheelin', I would stick with 33's if you have the stock drivetrain. 35's would look awesome but you will definitely be pushing the limits of the front & rear diff.
I never broke anything running 33s on mine & I tend to be hard on it, with the heavier 35s you would definitely be pushing it in my opinion. Just a thought.
Anyway, those wheels are awesome!! :icon_thumby: They are the same wheels I've been looking at!! Black wheels are bad @zz!! Can't wait to see 'em on there!! :icon_cheers:
B2
With a 6" lift and a fender trim, you should be able to clear at least 34's for hard wheeling and 35's otherwise. I have a total of 7" of lift on my Choptop and no fender trim and 33's look a lil small, IMHO.
But you run into gearing problems. I would say that 4.10s would be adequate for 33's, and 3.73s the bare minimum. For 35's I'd say that you should have 4.56 or 4.88.
That's part of why I haven't put 35's on my choptop yet, still gathering the things I need to regear and upgrade my axles. Kinda wishing I would have put a D-35 and 8.8 under it when I first put the suspension together...
Thanks for the input guys, I think I'll pick up a used set of 33's and then later on down the road if I want 35's I'll get them and maybe do some axle swapping. I will only be wheeling this thing so I'm going for function over looks.
If your B2 has 3:73s, you will turn 33s just fine. Mine has the 2.8 with 3:73s & I didn't have a problem at all! :headbang: Keep us updated, can't wait to see her done!! :icon_cheers:
If it's only gonna be for wheeling, I'd look for a set of 34" Swamper LTB tires, they dig real good and are only 10.5" wide like a 31" tire. My one buddy has a set on his Yeep and I've been impressed.
looks good! just put a set of the same wheels on my ranger with 33" TSL's on just a 3in body lift. I cut the fenders and im putting a 4in skyjacker class 2 lift on it and pulling the 3in body off. Good luck with the rest of the BII, I miss mine. On my 89 BII I had 35's with a 3in body and cut fenders and didnt have any problems although I was very careful while off road because I still had a dana 28 and a 7.5 rear.
Anyone know of reliable places to get tires that have decent prices ???
I got a lot done today, both front fenders removed, cut and painted, also painted that piece on the front below the radiator. Modified the splash guards for the front fenders, pulled the front and rear sway bars. Started to put the interior back together after I sealed the rear quarters from being cut.
