my rear brakes have me confused
ease
I have a 1995 4x4 ext. cab with the 3.0 automatic.
I believe I have rear abs. Leaf spring hanger broke, and it snapped a brakeline along with it, and I broke another just wiggling lines.
Anyways, there is a line that is coming from the drivers side of the frame, between the frame and gas tank that is corrugated (it has ridges like an electrical heat guard for a wire).
It's obviously broken, but I have no clue what it tapped into. It's end is near nothing that it could have broken off from, and from what I can tell, there is only one rear (non corrugated) line that goes to a T above the rear end.
Does anyone have a diagram, or better, pictures of the rear brakes with the bed off.
If it's easier, I'll just run a new line from the MC, but if it's a simple fix, I'd prefer to keep it stock.
It isn't "corrogated" the line has a protective wire covering wrapped
around the 3/16" diameter metal line.
AD
Ok thanks but where does it go to?
