tacstar
- Jun 7, 2010
- Automatic
Ok, I just swapped a motor from a 2001 Ranger into a 2000 Ranger that I bought with a blown motor. I swapped fuel injectors so they would work with my harness. Other than that, and the exhaust manifolds, everything went fine. I replaced the Cam Synchronizer as a preventative measure.
The truck now won't start. It does crank. I believe every sensor is hooked up (I've checked soooo many times). The truck has spark- I have observed spark at each spark plug. The fuel rail has 58 lbs of pressure.
I'm at a loss...I've spent a ton of time trying to diagnose the problem...I need ideas. Help!
