my ranger hates me!!
Status
Not open for further replies.
zaczany
so i once had this on the help section and if this isnt the right place then please correct me. i have a 93 3.0 ranger that i reciently did a motor swap. i drove it for a good while, then it died on me while driving so i got it home and got it running, i did a dist. cap and rotor and a fuel filter. but since then it wont accelerate. sometime it will. but i turn it off and go to leave agian its acting up. and if i floor it its good but anthing other than 10% or 100% throttle it wont accelerate. i figured the cat was clogged so i took it off, no dice. so i ended up changing the fuel pressure regulator, spark plugs, TPS, ECT sensor and oxygen sensors. i really dont know what else could be making my engine act like its clogged up. thanks guys?
As part of the "Urgant, help needed" subforum cleansing your previous thread was moved to the 3.0 subforum, which is probably the best place for it. You might bump it or add any new info you have to revive it.
http://www.therangerstation.com/forums/showthread.php?t=170634
And it doesn't hate you, it is just being ornery :icon_thumby:
Status
