- Aug 9, 2007
- Age
- 79
- C. Wisconsin
2000
199
- Manual
If you are running alt, fan (water pump), p.s you should be good with one belt.
You do not need a separate belt for each accessory
I think you are forgetting the crank pulley. Normally isn'tit crank to water pump to alt and for the other belt, crank to water pump to AC/PS? Thought it was normally three pulleys per belt.
Dave - probably having my normal brain cramp.
