ncsdaonex
- Dec 5, 2008
i blew my tranny out so i tried to take the old one off and i decided it was easier to pull the motor and tranny out to swap tranny's. while i was attemping to disconect things from the motor and i found problem after problem. The intake manifold was coated inside with what looked like a greasy gunk. So im gonna clean it out. All my fuel injectons, the bottom of them were cracked and covered with the gunk. As i was pulling the motor out and one of my motor mounts fell apart. My master cylinder to my clutch is leaking a little fluid out and my clutch was having problems every once in a while and i think it was due to that. I am going to replace all the motor gaskets and paint the motor while its out of the truck. I am thinking about replacing the clutch and slave cylinder while its out. Is that nessasary to do, also my clutch hydralic line has dirt in it. I have the motor halfway out but the tranny is bottoming out on the floor pan, so do i have do remove the beam the tranny bolts to. So are all those parts nessasary to change and do i have to unbolt that beam that the tranny bolts to and any other information would be helpful.
