Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
- Aug 2, 2000
- Age
- 57
- Nocona
- State - Country
- TX - USA
- Other
- 2005 Jaguar XJ8
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Automatic
- Total Lift
- 3.5-inches
- Tire Size
- 295/70/17
I have a Frigidaire refrigerator with the freezer on top. Nothing fancy, just a normal fridge/freezer.
A few days ago, the freezer started making a knocking noise, and it seemed like the fan in the back of the freezer was hitting something which I figured was an ice buildup, so I emptied out the freezer, unplugged it, and let it set for several minutes to thaw. When I plugged it back in it seemed to work ok and wasn't making anymore knocking sounds. I had quite a bit of stuff in my freezer, so I turned the temp down a little to try and keep the fan from freezing back up.
Today I went to grab a popsicle out of the freezer, and they were melted. My meals and meats are still frozen, but there's a pizza in there that has thawed. I turned the freezer back up, but 9-hours later, the popsicles and pizza aren't freezing. I also don't feel air blowing from the back of the freezer when I open the door, but I didn't get a clear answer searching online about whether the fan should blow cold air when the door is open. I had also moved everything away from the back of the freezer when I thawed it to make sure the airflow wasn't blocked.
Now I'm kind of at a loss as to what the issue is. It's cold but not freezing. I put it on a colder setting, and I'll check it in the morning, but I have a feeling it's going to require some attention.
