89sport
- Nov 15, 2008
I am starting my budget engine build and I am aiming to put it in around August. I still have a list of parts to get which include: e303, T-5, flywheel, clutch, hedman headers, 70MM throttle and egr spacer, MAF sensor to match the 24 lb injectors, timing chain and cover, harmonic balancer, A9L computer and wiring harness. I have more parts on my list but that's just the main parts that I am really looking for at the moment. I am going to stick with the stock E7 heads for right now unless I can find some GT40X/Y's dirt cheap. The only thing i can find is GT40P and I am trying to keep this all on a budget and GTP headers wont fit my budget.
Starting with the block
92-93 mustang XXX block - Forged pistons roller motor
I picked up a few parts at a swap meet for dirt cheap First off is Pro comp aluminum roller rockers
Also picked up a GT40 upper and lower intake
I found a really good deal on some 24 lb injectors for 40 bucks with only 25k miles on em. When i got home i noticed that there was an extra injector and I have no clue what flow it is.
