i have 65lb fuel pressure. will idle but acts like it is not getting fuel when i touch the gas pedal. thought it was bad gas so i drained the tank and new filter, but no change.
go ahead and get the bed off.. Spray the bolts from the bottom with some type of lube. They are very tight and hard to move even to the last thread.
Check the throttle position sensor before taking the bed off.
Also check your maf, carb, etc dunno the year or engine you hand I'm on tapatalk
