My door/hinges wobble like a saturday night drunk . . . how can I rebuild/fix'em ??
treeguy
Shelton, WA
I have a 1990 ranger ext cab . . . I did some searching on the forum and Allen D mentioned rebuilding his hinges , others have mentioned cheap rebuilt kits that would work . . . but I have called around and found absolutely no sources at any of the auto parts stores in the area . . . any ideas or DIY fix ideas would be very nice for these wore out hinges . . .
You can get hinge pins and bushings from Advance or Autozone. They aren't too expensive and the don't take but a little bit to put them in. Be sure to have a wooden block to support the door (from the ground) while you change them out. They should come in a pack with pins and bushings together.
I called autozone and they could not find a bushing/pin kit for that year . . . could you at all supply a part # for either Advance or Autozone ???? Thanks . . .
Advance Auto part #38350. That's one pin and 2 bushings for $5.90 +tax
The Autozone guys here can't find their asses with both hands, so I'm not surprised they can't find that part for you.
Twisted Steel,
Thank you for comming up with that P/N you just saved me an hour (or more)
worth of digging.
AD
Hey Allen.. No worries. I'm doing a V8 swap as we speak.. so I've got Advance Auto on speed dial!! :D
Treeguy.. Glad I could help. How close was the price from here to there?
Ummm . . . I checked online and it showed $30 dollars for that part number . . . maybe I will call tomorrow and have that verified . . . !!! Again thanks for the speedy input . . . !!
$30!!!?!?! Holy crappin hell!
Ok..i just called and re-verified the price and part number... 38350 @ <6.00
If they can't get under 30 bucks, I can buy it here, ship it to you and bypass the BS.
