My bed i need to know if this will work or not....
I have a Splash bed and i kinda want a normal bed... So would it work if i put in Some fiberglass bedsides that prerunners have? Would it coast more then the bed sides or what?
http://www.woolworthmotorsports.com/content/view/27/4/
I know you guys might just say to get a Normal bed.. Well how hard is it to install thos at home???:icon_confused:
to install a bed at home. you need a large torx bit and a few friends to help lift if off. of course disconnect the lights and the fuel filler
You would still need a normal bed to install the fiberglass box sides, the splash bed is narrower.
Um... no.
The bed you have is like 4 feet wide and fiberglass. The normal bed is like 5 feet wide. If you put the fenders on your step side it won't change the size of your bed at all. it will still be a 4ft wide bed, and it most likely won't even go out enough to cover the wheels... You need to get a regular bed if you want a regular bed...
change the bed for a normal one.
dont forget a normal bumper too, since yours is narrower
