Ok, i'm starting on my build with my 67 F-250 4x4. It has a closed knuckle dana 44 under it with drum brakes. I want to swap in a better axle, but don't know if I should go dana 60, or 44 for the front of it. I want to use this truck as a weekend driver/ playtoy/ hunt truck, and realistically don't want about about a 35" tire under it. Swapping in power steering will be later, but witht his axle swap I will also have to add power brakes. Now onto the rear, it is a dana 60, but from 67 I think it's coarse splins and weaker than newer ones. I want to upgrade it as well, but can I do it without having to swap entire axles?
