86 5.0L in my BII is Missing and lacking bottom end power. If I keep the rpm above 2000 it stays cleaned out and does ok, but if I idle around crawling it seems to load up, you can even smeel its running rich... It seems to do it worse at operating tempthan it does when its still "cold".
Fuel pressure is great, plugs and wires are good, cap and rotor should be good.
Injectors crapping out? I am just outa ideas.
Any Ideas, suggestions?
THANKS, Todd S.
THANKS, Todd S.
