Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS Banner 2012-2015
GMRS Radio License
TRS 25th Anniversary
- Aug 2, 2000
- Age
- 57
- Nocona
- State - Country
- TX - USA
- Other
- 2005 Jaguar XJ8
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Automatic
- Total Lift
- 3.5-inches
- Tire Size
- 295/70/17
The 302 in the old Ranger (TRS-1) was running fine except for an off idle hesitation. I contacted Holley and they had me send them my Offroad Avenger card for a replacement Ithe first series of these carbs had a known hesitation issue).
I pulled the engine out of the Ranger nad put it in to my Bronco II project after cleaning it up, painting it, and putting on some new valve covers. I also added a 2-inch spacer under the carb so the air cleaner would clear the distributor (and I think it's suppose to improve some low end power...or something like that.
Well, the damn thing won't start. I checked the timing, checked to make sure the spark plug wires were on the right cylinders, and switched between the MSD and stock Duraspark ignition.
No go. It makes a sound like it wants to start, but won't fire all the way. Since it sounds like it's trying to start, it tells me it's getting spark and fuel. Trying puring gas in the card and sounded like it wanted to start, and backfired (popped) through the carb.
So now I'm lost. I even put it back at #1 TDC to make sure it and the #1 at the distributor was in sync and that I hadn't got the distributor in the wrong spot.
While I was cranking it today, Vanessa saw some smoke starting to come out of the breather on the driver side valve cover. Actually, I think the first time I tried to start it that it might have popped the PCV valve out of the passenger valve cover because I saw it out and had to put it back in. Hasn't done it since.
Any suggestions? The motor ran fine the last time I drove it. Just had fuel issues from a crappy carb that got replaced.
