Dylan9302
- Sep 15, 2010
2) 199
- Automatic
ok ive seen many posts on here by searching but i cant seem to find my problem if indeed it is a problem. to begin its a 99 3.0 4x4 auto. the tranny is screwed i beleive seeing as it takes 1-5 seconds to engage to drive.. it also will not rev freely to accelerate. if i shift it manualy 120 seems to be all its got and parked seems to chug around 2200 rpm. i have a 5 speed to swap as soon as i get the time but want to get it running right first. the things i already have done are. plugs and wires (NGK from crappy tire), k&n air filter, oil pressure sensor, seafoam in the engine through brake booster. the vacume pressure tested good.
now i want to check compression but cant get my tester through the hole in the manifolds? i might grind the end just a little to see if it will fit but dont want to ruin the tool.
the exhause seems louder than it should be? sorta like the muffler is hollow but no leaks in the exhaust.
i really like this little ranger and want to get it running properly any ideas to try would help as long as its not a 100 dollar part to try.
if it would help i might be able to get a video of it running on youtube.
thanks dylan
thanks dylan
