Crashtest84
my 2.9maybe half toast. imput from you guys needed "updated info"
ok so I had posted over in another post about low power issues. To shorten the story up here I am not getting oil to the rockers and that has caused the rockers to gull a lil on the shaft. I priced shafts at about $35each new and rockers are about $17 each. So question is do I swap for a v-8 or try putting a new set of cam bearings, oil pump and lifters. Then try and find a good rocker assembly at a used lot. Money is kinda tight and a v-8 swap really isn't cheap but neither is a 2.9 rebuild, now I do still have good compression at 170psi give or take a few on all 6. Im kinda thinking to pull the motor and spend a lil on a cam bearing set pull the lifters clean and check them out and try to find a good rocker assembly total cost maybe 250 or so if im lucky. That will hopefully make it for a few months wile I find all my 302 swap parts I found a explorer for $200 still has all the harness the heads are gone and it needs a crank...
